Hi - I was able to install the WAB and create a sample application with a few widgets.I downloaded the WAB application, locally into my webserver and altered the proxyURL ,App ID ,Portal URL to empty and I accessed the application using http://servername/test-copy/index.html and I'm getting a blank page. Please advise what I'm doing wrong.
ArcGIS Web Application
here a link to the url which is public. I don't have any layers configured in here. I was hoping atleast the empty template would come up. Please advise. When I launch locally when the node.js is running and logged into the
ARCGIS online account , I see the application. Please advise.
Looks like your portal url is wrong. That is the error I get in the console. Your config has the portal removed.
Hi Paul - Just to give a little bit more backgroud. I'm trying to migrate from Flex Viewer to WAB using Javascript
we have a ARCGIS 10.3 server. Do I need a portal extension to run the code I downlaoded from
ARCGIS online ? I need to add the operational layers that are hosted in my ARCGIS 10.3 server and play around a bit with the widgets.
Will the WAB work in ARCGIS 10.3 or do I need to install the Portal Extension ? If Portal is not needed, should I sepcify the application URL in the config.json like http://<servername>/web-context/index.html. Am I headed in the right direction ?
config.json read me says portal URL is optional
//Optional. The portal URL. If empty, use the URL that app is hosted.
"portalUrl": "http://mypc.com/arcgis/"
Please advise.
Priya,
When you first start WAB you are asked for a portal url. This is the url for your AGOL organization and where your registered app is to get the app id. This is also the place where you will configure your web map for WAB.
When is says portalUrl it is not asking for the portal extension for server. It is asking for a url of the place that you configure your web maps and register your apps.Either Portal for Server or AGOL.
-Stan
