Hi
What's the SQL Server AlwaysOn compatibility with ArcGIS server, ArcSDE and ArcFM.
How replication happens in alwayson, does it support geometric Network, geoprocessing task, how it handles network traffic?
Tarun Punetha
Hey Shannon - just as an FYI - we have been using 10.2 (and now 10.2.2) with AlwaysOn - and it pretty much rocks.
Reasons:
- very reliable, well over 100 million REST requests that require SQL server data, and the Always on replica has not skipped a beat, with 90% of that during our fire season (Dec-March)
- easy to setup
- performance is amazing - at our highest peak load - the AlwaysOn replica never got over 9% CPU usage.
-Anthony
Hi Shannon,
Since we cannot use the applicationIntent=READONLY, Is it possible make direct connect to AlwaysOn READ ONLY replica in ArcGIS Desktop 10.2.2 ?
Thanks much,
Yeong Lin
Anthony,we don't fully support AlwaysOn at 10.1. At 10.1 you can connect to a read-only database, not a geodatabase. The ability to connect to a read-only geodatabase will be part of the 10.2 release. The ability to do read-only routing via the Listener using the APPLICATIONINTENT connection parameter will be available in the following release.-Shannon
