regarding to the application environment , the application shall have the following :creating a version , reconcile & post versions , adding users and groups and assigning permissions , reading KPI's for the SDE , in other language is this applicable to be built in a web application ??
my question is : can I use the arcobjects "server object extensions" to apply these functions ?? or do you recommend me to use something else ???
can server object extensions be used separately from any Arc Server service or instance ???and away from any Arc Serve API's ????
then if it lives in arcserver ,, is it connected to any service of arc server ??? I mean am I stuck to the map services and other services published on the arc server or it can work and manage the resources on the sde ?????
