I am trying to change the CSS of the feature from feature layer through the javascript API 3.2.1 .
Please check the attached file of pin image.
Thanks
Kamal,
You do not work with the CSS for symbols in the JS API as they are mainly SVG graphics. You need to change the Symbol class for that graphic.
Robert
I have updated the image of a pin . please check it again then you might be clear what i am asking for
So are you setting the point symbol using a picturemarkersymbol?
Robert,
No , it is the image coming from the feature layer. we are not setting anything in the javascript.
