Hello,I am having exatly (or mostly exactly) the same problem. Suddenly all of my projects stopped working - even when I run the index.html from their "home folder". I am using the Flash Builder 4.5 and IIS 7. Previously, I could run the index.html from "any place" on my computer and it did work. Now when I click the index.html (or run it from flex builder) I get the error #2148 and on the next page I get "Some error occurred. ExternalInterface doesn't work in Standalone player.". This happens even when I put the folder into my IIS 7 wwwroot folder.When I try the http://localhost/inetput/wwwroot/... adress, i get error 404.0 Not found, The resource you are looking for was removed, has changed or is currently unavalible.I have tried to restart the IIS7, update the Flash Player but nothing of this worked. When I put the application into the inetpub/wwwroot folder on my server, so everything works fine.Please help me, as developing applications and running them from a server is very time consuming!!Jan
サインインすると、投稿したり、更新をフォローしたりできます。初めての方ですか?無料アカウントを登録しましょう。
