2016年のUCクロージングセッションでマップギャラリーの受賞者が発表されたときの写真やビデオをお持ちの方はいらっしゃいますか? 私のマップギャラリーの作品はArcGIS Proカテゴリで2位を獲得しましたが、金曜日に参加できず、発表を見逃してしまいました。 <\/P>
<\/P>
ありがとうございます!!<\/P><\/BODY><\/HTML>
Cory, I have the picture of your ArcGIS Pro Map Award!
Your name along with Joe Gregory is mentioned on the slide.
2016 Map Gallery Results | 2016 Esri International User Conference
I'm glad he was able to help you out...I had little doubt that he would have at least one.. I went ahead and marked his answer as correct...in case you were wondering.
btw, unlike the plenary, they don't usually record, or at least post, the closing, because it can be unpredictable during the Q&A, I suspect. But I think a suggestion to record/post at least that portion would be nice (takes ~3-5 minutes), just for others like you that can't stay to the end.
Thanks! TAPAS DAS did have the picture.
Thank you so much for this!!
Yes, Rebecca is correct!
I was sitting on the front row, center, and took pictures of all the awards at the closing ceremony.
Let me look through my collections, and I will post it.
Congratulations Cory!!!
I don't see a picture if that on UC Updates Day 5: Closing Session, UC and GeoNet Awards, Open Q&A , but maybe they did not post it. But if they didn't get one, I bet TAPAS DAS has one, since he usually sits up close and takes lots of pics.
my iPad is acting weird right now, so I need to double check it grabbed the correct account for him...
yes, that is the correct one.
congrats btw!
