Hello,I have errors running this viewer with Google Chrome Versión 31.0.1650.63 m, the toolbat donpt appear, and a lot of errors appear both in the Application Builder, and in the Viewer. Only with IE work well.Thanks[ATTACH=CONFIG]29730[/ATTACH]
I have error "no elrment found" when start Builder with new 3.2 version 64 bit Russian, Windows 7. I can't start Builder after re-install Viewer also.Help me please.Thanks.
A new Query Layer tool that allows application designers to interactively define complex queries, while showing end-users a simple dialog consisting of labels, textboxes, and drop-down menus for inputting query valuesI run the install to upgrade 3.1 to 3.2 its seam everything go well. But the only thing why I make the update is the define complex queries and I dont have, the Query Layers stay the same that 3.1 , I reload from the setting add tool, where I can have that new Query Layer tool to over kill my older one, or what is the way to correcte that installation... Also the module go to coordinates IS NOT SUPORTED IN 3.2, I hope somebody will make the update..Many thanks to all of you...Its a great interface...
