Learn_ArcGISを使用しているときに分析ボタンを表示させるにはどうすればよいですか?<\/P><\/BODY><\/HTML>
Hi Steve,
I have some more detailed information for you now which I hope will be more helpful.
Do you see a Pricing tab on the ribbon at the top of the ArcGIS Online website?
If you do not see the Pricing tab, you are part of an organization.Click on the Organization tab at the top of the page.
If you have all of the correct privileges, it may be that you are trying to perform analysis on an incompatible layer like a tile layer.
I hope this helps, and I apologize for taking a while to get a properly thorough answer to you!
Heather
What Esri software are you using? ArcGIS Pro? ArcMap? Insights for ArcGIS? Do you have a link to the step in the lesson you're working on?
If you are using ArcGIS Online, the Analysis button may be unavailable if your account is missing certain privileges, which you can check here: Use the analysis tools—ArcGIS Online Help | Documentation
It may also be missing if you have run out of credits on your account.
These are both things that your organization's administrator can fix for you.
Thanks for responding Robert and Heather,
I'm just beginning to learn using lessons like this: Fight Child Poverty with Demographic Analysis | Learn ArcGIS
I got to this page to do the lesson and clicked on "Make A Map.": http://www.arcgis.com/home/index.html
I don't have an administrator, just trying to learn this on my own for future use.
When I get to the "Enrich the Layer" Section, it mentions an "Analysis" button. Create a map—Fight Child Poverty with Demographic Analysis | ArcGIS
Thanks Steve,
What kind of account do you have? For example, are you using the ArcGIS free trial? or an account with the Learn ArcGIS Organization?
When you are on the Organization tab in ArcGIS Online, do you see additional tabs for Licenses, Status, and Settings?
If you do, then you are your own administrator, and will be able to see how many credits you have remaining, and configure your member role.
If not, we will need to figure out who administers your organization.
You may also find this response relevant: https://community.esri.com/message/687812-i-dont-have-perform-analysis-button?q=analysis%20button
You can get a free trial via here or here.
Hello Heather,I know the topic is old, but based on your answer, I believe you can help me. I am my own administrator (I can see the Licences, Status and Settings options). What I need to do to be able to use the Analysis tools within Map Viewer? How exactly I need to configure my member role?Thanks!!
Hello, I have an administrator account and I am a teacher within an Organization. I have about 50 students as creators. We keep trying to use the analysis tool stated in ESRI lessons, but it doesn't appear. I have them all set as Creator Publishers and we have tried a bunch of the lessons here following steps and have verified that layers should have analysis option. Please help !! :
https://education.maps.arcgis.com/apps/instant/filtergallery/index.html?appid=286264302cdb426e8f87cb0f62790154
