Executing: CreateEnterpriseGeodatabase PostgreSQL myarcgisserver,4321 ghana DATABASE_AUTH postgres ***** SDE_SCHEMA sde ***** # C:\Users\Schlomm\Desktop\keycodesStart Time: Mon Aug 19 12:50:14 2013User has privileges required to create database objects.Geodatabase admin user created.Database created.Validated authorization file.User has required privileges for geodatabase setup.XML support is enabled for the database instance.Connected RDBMS instance is setup for Esri spatial type configuration. For now about 20 minutes without any change.
Type the database name in lower case; upper- and mixed-case object names are not supported for geodatabases in PostgreSQL.
You have to specify an sde user name and password when creating a geodatabase in PostgreSQL. Since this tool also works with SQL Server and Oracle, for which the sde user name and password might not be needed, the tool shows those parameters as optional. However, they are not optional for PostgreSQL. Unfortunately, gp tools are not context sensitive in that way.Since you already have an sde login role, so be sure you specify the password of that existing sde login when you run the tool again.
Executing: CreateEnterpriseGeodatabase PostgreSQL dornroeschen.xyz.de,5432 data DATABASE_AUTH postgres ***** SDE_SCHEMA sde ***** # C:\Users\Schlomm\Desktop\keycodes Start Time: Thu Aug 22 16:49:38 2013 User has privileges required to create database objects. Geodatabase admin user created. Database created. Validated authorization file. User has required privileges for geodatabase setup. XML support is enabled for the database instance. Connected RDBMS instance is setup for Esri spatial type configuration.
Out of curiosity, is your PostgreSQL server a VM?
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
