The Fishnet tool has an extent and if you select it as a parameter you get a drop down of all the [feature and raster layers] only within the working mxd. What I'd like to do is have the ability to set the Template Extent values (Top Bottom Left Right) to the values obtained from the Environment Settings > Processing Extent using the "Same As Display" option.
When I do what you have suggested, I can see the options in my tool, select "Same as Display" but the values of Top Bottom Left Right don't get sent to their respective counterparts in the Extent part of the Fishnet tool. Were you able to actually tie these together?
