private function searchDrawEnd(event:DrawEvent):void { event.target.deactivate(); var geom:Geometry = event.graphic.geometry; if(geom.type == Geometry.MAPPOINT) { //Expand the point by 5 pixels var point:MapPoint = geom as MapPoint; var xMin:Number = map.toScreen(point).x - 2.5; var yMin:Number = map.toScreen(point).y - 2.5; var xMax:Number = map.toScreen(point).x + 2.5; var yMax:Number = map.toScreen(point).y + 2.5; var mp1:MapPoint = map.toMap(new Point(xMin,yMin)); var mp2:MapPoint = map.toMap(new Point(xMax,yMax)); var ext:Extent = new Extent(mp1.x, mp1.y, mp2.x, mp2.y); var pA:Array = []; var pPoly:Polygon = new Polygon(null,geom.spatialReference); pA.push(new MapPoint(ext.xmin,ext.ymin,geom.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymax,geom.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymax,geom.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymin,geom.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymin,geom.spatialReference)); pPoly.addRing(pA); queryFeaturesGraphical(pPoly); } else { queryFeaturesGraphical(geom); } }
Joshua, There is not tolerance built in for the point graphical search so you have to add one on your own like this:private function searchDrawEnd(event:DrawEvent):void { event.target.deactivate(); var geom:Geometry = event.graphic.geometry; if(geom.type == Geometry.MAPPOINT) { //Expand the point by 5 pixels var point:MapPoint = geom as MapPoint; var xMin:Number = map.toScreen(point).x - 2.5; var yMin:Number = map.toScreen(point).y - 2.5; var xMax:Number = map.toScreen(point).x + 2.5; var yMax:Number = map.toScreen(point).y + 2.5; var mp1:MapPoint = map.toMap(new Point(xMin,yMin)); var mp2:MapPoint = map.toMap(new Point(xMax,yMax)); var ext:Extent = new Extent(mp1.x, mp1.y, mp2.x, mp2.y); var pA:Array = []; var pPoly:Polygon = new Polygon(null,geom.spatialReference); pA.push(new MapPoint(ext.xmin,ext.ymin,geom.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymax,geom.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymax,geom.spatialReference)); pA.push(new MapPoint(ext.xmax,ext.ymin,geom.spatialReference)); pA.push(new MapPoint(ext.xmin,ext.ymin,geom.spatialReference)); pPoly.addRing(pA); queryFeaturesGraphical(pPoly); } else { queryFeaturesGraphical(geom); } }
