The GPS icon goes off screen and I have to keep pressing the location button to center it again. Is there a way to fix this?
Hi Shea - If you are using Collector, your location stays centered on the map until you pan. Once you pan the map, your location will be allowed to wander about the screen. If you aren't seeing it stay centered before you pan the map, please give us some more details and we can investigate it.
