When I applied complete Streets rule http://www.arcgis.com/home/item.html?id=863f4e7139314101a5cee1d7cde079d9David Wasserman
Are you applying this to CAD Polygons? The complete street as it stands now only operates on centerlines (Street Graphs).
A maintained version of the rule is here too: GitHub - Holisticnature/Complete_Street_Rule: This is an updated repository for a modified version of the ESRI Complete …
Oh I see.... No I'm not using CAD but polygon from ArcGIS. Maybe I am be able to extract their centerlines in ArcGIS..
You can also just draw streets using the editing tools if using the centerlines is too much of a hassle. I sometimes do this for small scenes.
Sorry I didn't have a chance to reply to your post. Thank you so much. It worked out pretty well.
