I may have misunderstood the question. When I use pop up solution in ArcGis Portal to create a map and want to write my own text in the popup the problem appears. I highlight a text and choose hyperlink tool(the chain) and if the link starts with ftp:// it works in the session but if i logout it changes it to http:// by itself. See my before and after pictures.
before
after
I am able to add an item to My Content that reflects an FTP url. Perhaps you are experiencing a different issue.
Mike
Hi! This issue still seems not to be resolved?
Is there anyone that have a solution?
This may work for you.From My Content, choose Add Item. Item is on the web. Choose Document Link as the type and enter the URL.Thanks,Mike
ArcGIS Web API REST Connectionhttp://ftp://www.bcogc.ca/outgoing/OGC_Data/ePASS_Documents/ePASS_Standards_Requirements.pdf
