map.scaleBarVisible=false;
Miguel, It is going to be in code. The viewer team did not make every little detail configurable. So in the mapmanager you need to add map.scaleBarVisible=false; somewhere like in the if statement of the protected override function partAdded.
scalebarvisible="false"
public static const DEFAULT_CONFIG_FILE:String = "config-all.xml";
