Hi Alaeddine,Currently, ArcSDE doesn't support columns with identity property set to True. Tables/Feature classes with this property cannot be edited in ArcMap or registered as versioned. When attempting to create non-versioned edits in ArcMap you will receive an error similar to:"Database Row Change: An unexpected failure occured.Underlying DBMS error[Microsoft sql server Native Client 10.0: Cannot insert explicit value for identity column in table 'tableName' when IDENTITY_INSERT is set to OFF.][..tableName]."
I'm with Brian. It's simply ridiculous that ESRI STILL does not support a PRIMARY KEY with Identity Column sequence generator in the enterprise database they say the support! If you don't support the primary key you should not say you support the database.
That and the limitation of only being able to have one feature type per table (feature class). All other open source and proprietary geodatabases support this feature and have done so from day 1. ESRI is falling behind in a huge way on many basic levels. It makes developing with their product a nightmare.
Jake,
Do you know if the most recent version of ArcSDE supports column with IDENTIFY properties? I was just trying to set it up, and when I tried to edit my data in ArcMap I got the same error that you were talking about four years ago .
Thank you,
Nataliya
Hi Nataliya,
Unfortunately, this is still not supported.
Thank you Jake. Is there any other way to auto-generate sequential number in a feature class, without setting "IDENTIFY" property on the column through SQL?
Take a look at the Water Utility Network Editing solution. Included with this is the attribute assistant add-in. Below is a good help link that walks you through the different methods the add-in provides:
Overview - Attribute Assistant | ArcGIS Solutions
For example, take a look at the autonumber method:
Attribute Assistant methods - Attribute Assistant | ArcGIS Solutions
I'm needing it in Web AppBuilder editing!
Web AppBuilder for ArcGIS
Ditto Venus Scott, we need as well
Hi Jake,
Do you know if the most recent version of ArcSDE supports column with IDENTIFY properties? It has been three years, and I was wondering it this capability is available now.
George
Does ArcSDE support columns with identity property set to True yet?
