Hello,All configuring for coded-value domain is done prior to consuming the service in the ArcGIS Viewer for Silverlight. You may need to verify the settings on your layer/published service. For comparison, ssee the following service where the Facilities layer has coded-value domains and the Label appears in pop-ups and the attribute table instead of the domain value: http://sampleserver5a.arcgisonline.com/arcgis/rest/services/LocalGovernment/Recreation/FeatureServer/0Katy
has anyone found a solution for this problem. I am using ArcGIS 10.5. It is showing subtype codes instead of description. But the field domains are working fine.
I also have this issue with Portal 10.5 . AGS isn't publishing my feature service with the coded values for some reason. Any ideas?
