To GISDev:I was wondering if you have a basic viewer application setup that uses your own mapservices with pop-ups and all the widgets appear as expected at start-up, without requiring a refresh of the browser?The reason I ask is because in the following post "Issues upgrading Flexviewer 3.1 (uncompiled)" from 12/18/2012 other users were commenting about the same issue and the ESRI person was unable to confirm whether this was a bug or not.I am having the same issues as the original poster of this thread.
<map esrilogovisible="false" wraparound180="false" initialextent="549317 122136 603788 152861" fullextent="549317 122136 603788 152861" top="40" wkid="32149" addarcgisbasemaps="false" >
Looks like the CDATA section of my popups might be the culprit. When I remove it, the viewer seems to display without the need to refresh. Not sure why this has changed between 3.0 and 3.1, but at least we're moving in the right direction.
I was hoping to close this out and mark as answered but we're still having issues with the popups after all. I might be sticking with 3.0 for now.
If anyone is working with the uncompiled source code, you could try the code change from Roberts post hereIt seems to be working for me...
I have an incident with ESRI. I will report the outcome in this thread.Mark
