答えはノーだと思いますが、私の知る限り大きなプラットフォームの変更はないので、一応確認してみました。<\/P>
<\/P>
チームは今後6ヶ月以内に 10.3 バージョンを作成する予定がありますか、それともしばらくの間 10.2.2 を使い続けるべきでしょうか?<\/P><\/BODY><\/HTML>
There is a 10.3 version available for Arc Hydro (10.3.0.1) that can be downloaded both from the ftp site and from the following location:
http://downloads.esri.com/ArcHydro/ArcHydro/Setup/10.3/
Christine Dartiguenave
Esri Water Resources Team
Finally got around to checking, and the 10.2.0.85 msi package installer fails its PreInstall checks with this error:
Likely a simple adjustment in the installer, but it will need to be rebuilt for 10.3
Stuart
I have found that by editing the MSI file with ORCA does wonders for tools that perform a software version prerequisite check. Just remove the line that has something to do with the version of ArcMap. Granted, ArcHydro (and others) may not have been compiled against 10.3, and you may get some unexpected errors. I've only encountered one issue with a tool that was compiled for 10.1....forced an install for 10.2 and only one function doesn't work.
Tom colson, *,
First thing I looked for when reviewing with Orca but could not find it. If you spot the stanza to edit, post it and I'll give it a go. Otherwise we'll need to wait for the Water Resources group to post revised installer. Christine Dartiguenave and comment?
I "think" that
is what it's looking at. I'm using the 64-bit version of the installer. If you delete that statement? Unfortunately I don't have any machine I can test this on.
Unrelated to the actual question, although I feel the content is suitable for this thread.
I had a major issue with installing it into my computer, the arc hydro 10.3.x. The arc hydro tool was trying to save through a folder path that no longer existed in my drive. For some reason when I updated from version 10.2.x to 10.3 for my Arc Map, it erased ARCGIS home file from my drive. Follow the error and create the path that is in the error. Create a new folder and load up all the relevant folders, particularly the .bin file. After that it works like a dream. I hope this helps anyone that has shared the same frustration as I have had.
Cheers,
Allen McCoin
Every version of arcgis have the proper archydro installer
arcgis 10.2 and 10.2.x-->yellow.esri.com - /archydro/archydro/Setup/10.2.x/
arcgis v10.3 and 10.3.x--> yellow.esri.com - /archydro/archydro/Setup/10.3/
you need always to choose the last build available, and apply every patch to your arcgis, to avoid problems.
Thank you so much! ArcHydro tools is already working on ArcGIS 10.3.1
It will not. You need to install the 10.3 version for ArcGIS 10.3/10.3.1. You can download the latest build from the following location
http://downloads.esri.com/archydro/archydro/setup/10.3
Christine
