any body point me in the right direction for the best way to combine 2 sample widget for example identify and find, Using 2 separated js files. Just need to call them in the main.js
It is AMD Here is the link to Esri overview site Park Locator | ArcGIS for State Government
This is how esri does it in parks guide
<script type="text/javascript"> loadJS('//js.arcgis.com/3.11/init.js', true); loadJS('app/maptour-config.js'); function getUrlVar(name) { var vars = [], hash; if( window.location.href.indexOf('?') == -1 ) return null; var hashes = window.location.href.slice(window.location.href.indexOf('?') + 1).split('&'); for(var i = 0; i < hashes.length; i++){ hash = hashes.split('='); hash[0] = hash[0].split('#')[0]; vars.push(hash[0]); vars[hash[0]] = (hash[1] == undefined) ? "true" : hash[1]; } return vars[name]; } if( isProduction ) { if( getUrlVar('edit') || getUrlVar('fromScratch') || getUrlVar('fromscratch') || getUrlVar('fromGallery') ) loadJS('app/maptour-builder-min.js'); else loadJS('app/maptour-viewer-min.js'); } else { loadJS('lib/_jquery.1.9.1.min.js'); loadJS('lib/bootstrap/js/bootstrap.min.js'); loadJS('lib/spin.min.js'); loadJS('lib/history.min.js'); loadJS('lib/cubiq.iscroll.js'); loadJS('lib/cubiq.swipeview.js'); loadJS('lib/jquery-ui-1.10.0.custom.min.js'); loadJS('lib/jquery.ui.touch-punch.min.js'); loadJS('lib/jquery.exif.js'); loadJS('lib/jquery.fastClick.js'); loadJS('lib/jquery.hammer.min.js'); loadJS('lib/megapix-image.js'); loadJS('lib/spectrum/spectrum.js'); loadJS('lib/bootstrap.file-input.js'); loadJS('lib/colorbox/jquery.colorbox-min.js'); } </script>
Yeah, I don't know the parks guide app, but that is some custom loading of non-module code.
You can start here.
Embrace your AMD modules
Get familiar with how to write AMD modules and you'll be good to go.
Thank you Rickey, this example is very complicated , is it a legacy version or AMD version,, If you know any simple example using AMD that combining 2 or more widget.. with separated js file for each widget please let me know
Hi Rene,
Thank you, Will try your link again, Actually I read your book "ArcGIS Web Development" but still things are confused.. if you can include a very simple example of how to join 2 of the sample Code provided in the sample code page.. it would be more helpful for beginners like me.
Regards
Thanks! Appreciate it.
I don't have a sample using the widget samples, but I do have this simple sample on my github account.
GitHub - odoe/esrijs-modular: Sample modular app
Thank you, will go through the example and get back to you..
Rickey,
Thank you for the Link.
Its a good start to understand the AMD, Its using API 3.13, is there any big differences between 3.13 and 3.16
Thanks
