My question is the next. Can you create Reports with City Engine? I mean, to create a Report to export a PDF, related with the data included in the map and layres (Like in Arcmap). Thanks
Have a look at tutorial 1 Introduction to the CityEngine tutorials—Esri CityEngine | ArcGIS Desktop
Thanks for the answer.
But the problem is still there. I need to create reports, similar as in Microsoft Access... And in Arcmap you can do it with "Create Report".
So the question is, can I do it in CityEngine? This question is due to creating reports. In Arcmap, I would like to work in 3D but it is not possible. Therefore, I could use ArcScene, but there the reports don't exist, only graphs. Because of that, I am seeking another way to work.
Thank you for your input.
In CityEngine it is not possible to create reports in the style of ArcGIS.
One Solution would be to export your data via file GDB to ArcGIS and do the reporting from there.
Visualization of reports is a topic the CityEngine team is currently working on.The goal is to give city planners the information they need to communicate in simple to understand diagrams.
