Well, recompiling with version 2.2 certainly fixed the problem but I was just curious about the "plug and play" aspects of using precompiled widgets. Do you know if newer widgets are backward compatible, that is will work in an older viewer, or do you always need to be on a consistent build?
I am using the api 2.2 and I am trying create a new widget, but i can not to inherit from the BaseWidget because i can not find it on API!!! Can anyone help?
Was the widget compiled for Viewer 2.1? Are you trying to add it to a 2.2 Viewer?
