The change in sign is not a mistyping. This is to do bias correction.I wrote a simple test in Mathematica and the result for quantile map matches.Attached the test:Code.txtSource code to simulate data with Exponential covariance function (Exponent(-3*h)).Nugget=0Sill=1Range=1Quantile=0.9The prediction done in point (0,0) .Remark. This code is only for testing.OrdinaryKrigingQuantilePrediction.png �?? Wizard first page.SemivariogramParameters.png �?? Wizard page of semivariogram parameters.QuantilePrediction.png �?? All data are used as neighbors. Quantile prediction at point (0,0). TestData.* - Source data in shapefile and txt formats.Result in test code 2.15823Result in Wizard 2.1582296949642736
