when I load the map service into the JavaScript API using a basemap, my map for North Carolina shows up in Africa.
Re-projecting into WGS84 Web Mercator seems to have worked. Thanks! I figured I would have to re-project my layers but wanted to make sure before I went through all the work.
You dont have to reproject anything!!!!! Just change your data frame properties. The data can stay in its native projection.
