Hello Luiz,You need to modify the server name from localhost to the name of your BusinessObjects server on which you deployed the Esri Maps for SAP BusinessObjects server components. e.g. http://mycompany.com:8080. Also if your server is running on a port other than 8080, change the port number as well. For more information on Installing the client-side components kindly refer to the online help http://location-analytics.arcgis.com/en/maps-for-sap-bobj/install-and-configure/install-client-side-components.htm Hope this helps.Shirley
I did all procedures. Have changed from localhost to the server name, same error. See the attachment.
Hello Luiz,I noticed from the screenshot you attached that the em4bob.properties file is not in the correct path. Please nagivate to the the assets sub-folder within the Xcelsius folder and create a new subfolder named em4bobj.e.g. C:\Program Files (x86)\SAP BusinessObjects\Xcelsius 4.0\assets\em4bobjCopy the em4bobj.properties file to the newly created em4bobj folder. You should now be able to launch the Esri Maps Designer. Thanks,Shirley
