Collada export is new in version 10 so this blog article only applies to version 10. This only means that you cannot export ArcGIS multipatch to SketchUp but you can use the SketchUp 6 plugin to export TIN and vector feature classes. (In version 10 vector featurs cannot be easily exported unless polygons which need to be converted to multipatch first)In ArcGIS 9.3.1 and older you can use a command to import SketchUp 6 models but georeference information is not imported.
Hi, there is also a video on the 3DGIS resource center showing this particular work-flow:http://blogs.esri.com/Dev/blogs/3dgis/default.aspxRegards Gert
SketchUp will not open Collada file. The files I try to open are .dae SketchUp gives me a message saying "this does not appear to be a SketchUp Model"
ćµć¤ć³ć¤ć³ććć”ć³ćć¼ćÆę稿ćę“ę°ć®ćć©ćć¼ćŖć©ćć§ćć¾ććåćć¦ć§ććļ¼ē”ęć¢ć«ć¦ć³ććē»é²ćć¦ćć ććć
