Using the latest 3.3 version on 10.1 SP1, is it possible, using the Flex Edit Widget, to enter XY coordinates at object creation time? If Not, is it possible, via the default Flex Editor widget, to EDIT the XY coordinates of an already-created point feature? I realize it is very easy to create X and Y attribute field, goal here is allow people to enter XY at creation time so that the point feature reflects XY obtained, from say, a GPS or other coordinate source.
Hi Tom,
Just seen your post after I posted a similar question - did you ever get a solution ?
