Hello Guys...I am new to the sde services provided by esri. I want to connect ArcCatalog 10.2 to my Oracle 11g R2 database usingArcSDE 10.2. I am using a 64-Bit Windows server 2008. Till now following are the steps that i have undertaken:1) Installed Oracle 11g2) Created a Database named "MASTER"3) Configured a listener4) Installed ArcSDE 10.25) Default entries regarding the service name and port number have been made in the services file(esri_sde 5151/tcp).6) The Path environment variable has been set keeping %SDEHOME%/Bin as the first entry7) Create SDE service using sdeservice -o create command.Is it necessary to create an enterprise geodatabase before setting up the arcsde service? I assumed that it was meant to be doneafter the service was started.
Create a geodatabase by doing one of the following:-Run the Create Enterprise Geodatabase geoprocessing tool from ArcGIS for Desktop (Standard or Advanced) to create an sde user, default tablespace, and a geodatabase. -Run a Python script from a computer running ArcGIS for Desktop (Standard or Advanced), ArcGIS Engine with the Geodatabase Update extension, or ArcGIS for Server Enterprise (Standard or Advanced). Depending on which script you run, you might need to create the sde user and tablespace prior to running the script.-Manually create an sde user and default tablespace in your Oracle database, grant the sde user privileges to create a geodatabase, then connect to the Oracle database from ArcGIS for Desktop (Standard or Advanced) as the sde user and enable geodatabase behavior. See Enabling geodatabase functionality in an Oracle database for instructions.
Is it necessary to create an enterprise geodatabase before setting up the arcsde service?.
Actually, it isn't necessary for the geodatabase to be created before the service is created, but it is necessary to have had geodatabase installation completed before actually starting the service.
Is it necessary to create an enterprise geodatabase before setting up the arcsde service? I assumed that it was meant to be done after the service was started.
Hello guys !! Thanks for your help...Could your please help me with the steps in creating a enterprise geodatabase.Presently I have a database DB: OracleInstance: orclI am totally confused... And how do i make a sde user? I had used post installation before...It used to have repository stetup, table space creation etc etc...but now I am not able to do so...Please guide me step wise...
thanks nidhinkn... I tried the create enterprise geogatabase tool but its gives an error... "ora-12154 TNS : could not resolve the connect identifier specified No extended error Failed to execute "
Direct Connect is certainly your easiest option, but you can always try reading thedocumentation on how to connect using an application server.In the future, please start a new thread when you want to ask a question unrelatedto the previous topic.- V
