import widgets.TOC.toc.tocClasses.TocItem;
private function showMeta(evt:Event):void { if (data is TocItem) { var item:TocItem = TocItem(data); if(item.ttooltip && item.ttooltip != ""){ var mydetailswindow:DetailsWindow; mydetailswindow = DetailsWindow(PopUpManager.createPopUp(ViewerContainer.getInstance().mapManager.map,DetailsWindow,false,PopUpManagerChildList.POPUP)); mydetailswindow.windowDetails = item.ttooltip; mydetailswindow.iconDisplay.source = _Icon2; mydetailswindow.detailsTitle = item.label; PopUpManager.centerPopUp(mydetailswindow); } } }
<expanded>false</expanded>
<widget label="Map Contents" x="75" y="100" width="440" height="700" preload="open" icon="assets/images/i_folder.png" config="widgets/TOC/TOCWidget.xml" url="widgets/TOC/TOCWidget.swf"/>
