Andrew, I don't know what the issue is YET but I am now looking into it. Hopefully I can resolve it soon.Thanks for letting me know.
<viewer:WidgetTemplate id="wTemplate" height="300" skinClass="com.esri.viewer.skins.WidgetTemplateSkin" width="380"> <s:BorderContainer borderVisible="false" backgroundColor="#ffffff" backgroundAlpha="0.6" height="100%" width="100%"> <s:VGroup id="showTOC" visible="true" gap="8" height="100%" paddingTop="4" width="100%"> <s:HGroup gap="10" verticalAlign="middle" visible="{alphaVis}" includeInLayout="{alphaVis}"> <s:Label styleName="WidgetText" text="Layer Visibility" paddingLeft="6"/> <mx:Image source="{alphaIcon}" width="20" height="20" toolTip="{AlphaToolTip}"/> <s:HSlider id="slider" minimum="0" maximum="1" change="setLayerAlpha()" dataTipFormatFunction="sldrDataTipFormatter" liveDragging="true" snapInterval="0.001" skinClass="widgets.TOC.alphaSliderSkin" enabled="{layerIsSelected}"/> </s:HGroup> <s:Scroller id="scr" width="100%" height="100%"> <s:Group> <s:layout> <s:VerticalLayout gap="1"/> </s:layout> <s:HGroup id="boxMessage" width="100%" includeInLayout="false" visible="false" verticalAlign="middle" horizontalAlign="center"> <mx:Image id="swfMessage" source="widgets/TOC/assets/images/loader.swf"/> <s:Label id="txtMessage" width="90%" text="{GeneratingLegendMsg}"/> </s:HGroup> <toccomp:TOC id="toc" width="100%" height="100%" itemRollOver="setLastTreeItem(event)" itemClick="setSelectedTreeItem(event)" metadataToolTip="{MetadataToolTip}" showMetadataButton="{showDesc}" expanded="{expanded}" legendCollapsed="{legendCollapsed}" liveScrolling="false" variableRowHeight="true" tocMinWidth="{wTemplate.width - 45}" scroller="{scr}" loader="{boxMessage}"/> </s:Group> </s:Scroller> </s:VGroup> </s:BorderContainer> <s:BorderContainer width="{slider.width}" height="{slider.height}" includeInLayout="{alphaVis}" x="{slider.x}" y="{slider.y}" alpha="0.01" visible="{!slider.enabled}" toolTip="{AlphaToolTip}"/> </viewer:WidgetTemplate>
Danny and Andrew, I have uploaded version 2.4.1 today that has the memory leak fixed and I added back in the Flex Viewer 2.3.1 compiled version to the download in case you have yet to update to Flex Viewer 2.4.
