I need to display and edit polygon but problem is inย updatesketchview model they are using different coordinates format like this:
Rajni,
ย To update a graphic using SketchViewModel, the graphic has to be in the same SpatialReference as the map. So in this case you use WebMercatorUtils to project the polygon to webmercator before you add it to the map.
<SPAN class="operator token"><</SPAN><SPAN class="operator token">!</SPAN>DOCTYPE html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>html<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta charset<SPAN class="operator token">=</SPAN><SPAN class="string token">"utf-8"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>meta name<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewport"</SPAN> content<SPAN class="operator token">=</SPAN><SPAN class="string token">"initial-scale=1,maximum-scale=1,user-scalable=no"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>title<SPAN class="operator token">></SPAN>Intro to MapView <SPAN class="operator token">-</SPAN> Create a 2D map <SPAN class="operator token">-</SPAN> <SPAN class="number token">4.14</SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>title<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>style<SPAN class="operator token">></SPAN> html<SPAN class="punctuation token">,</SPAN> body<SPAN class="punctuation token">,</SPAN> #viewDiv <SPAN class="punctuation token">{</SPAN> padding<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> margin<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">0</SPAN><SPAN class="punctuation token">;</SPAN> height<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> width<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">100</SPAN><SPAN class="operator token">%</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>style<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>link rel<SPAN class="operator token">=</SPAN><SPAN class="string token">"stylesheet"</SPAN> href<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.14/esri/themes/light/main.css"</SPAN> <SPAN class="operator token">/</SPAN><SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script src<SPAN class="operator token">=</SPAN><SPAN class="string token">"https://js.arcgis.com/4.14/"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Sketch/SketchViewModel"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/Polygon"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/support/webMercatorUtils"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">,</SPAN> WebMap<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> SketchViewModel<SPAN class="punctuation token">,</SPAN> Polygon<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">,</SPAN> webMercatorUtils<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">let</SPAN> sketchViewModel<SPAN class="punctuation token">,</SPAN> validSymbol<SPAN class="punctuation token">,</SPAN> newDevelopmentGraphic<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/************************************************************ * Creates a new WebMap instance. A WebMap must reference * a PortalItem ID that represents a WebMap saved to * arcgis.com or an on-premise portal. * * To load a WebMap from an on-premise portal, set the portal * url with esriConfig.portalUrl. ************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> webmap <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">WebMap</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> portalItem<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// autocasts as new PortalItem()</SPAN> id<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"a8e76ad6641b46978f148cba03ab3e2d"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">/************************************************************ * Set the WebMap instance to the map property in a MapView. ************************************************************/</SPAN> <SPAN class="keyword token">var</SPAN> view <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">MapView</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> map<SPAN class="punctuation token">:</SPAN> webmap<SPAN class="punctuation token">,</SPAN> container<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"viewDiv"</SPAN><SPAN class="punctuation token">,</SPAN> center<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9258624</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.55590445</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> zoom<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">20</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">var</SPAN> graphicsLayer <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">GraphicsLayer</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> webmap<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>graphicsLayer<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="token function">setUpGraphicClickHandler</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">when</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// Add the boundary polygon and new lot polygon graphics</SPAN> <SPAN class="token function">addGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Create a new instance of sketchViewModel</SPAN> sketchViewModel <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SketchViewModel</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">,</SPAN> layer<SPAN class="punctuation token">:</SPAN> graphicsLayer<SPAN class="punctuation token">,</SPAN> updateOnGraphicClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN><SPAN class="punctuation token">,</SPAN> defaultUpdateOptions<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// set the default options for the update operations</SPAN> toggleToolOnClick<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">false</SPAN> <SPAN class="comment token">// only reshape operation will be enabled</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Listen to sketchViewModel's update event to do</SPAN> <SPAN class="comment token">// graphic reshape or move validation</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"update"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"undo"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"redo"</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> onGraphicUpdate<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">onGraphicUpdate</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// get the graphic as it is being updated</SPAN> <SPAN class="keyword token">const</SPAN> graphic <SPAN class="operator token">=</SPAN> event<SPAN class="punctuation token">.</SPAN>graphics<SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// check if the update event's the toolEventInfo.type is move-stop or reshape-stop</SPAN> <SPAN class="comment token">// then it means user finished moving or reshaping the graphic, call complete method.</SPAN> <SPAN class="comment token">// this will change update event state to complete and we will check the validity of the graphic location.</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> event<SPAN class="punctuation token">.</SPAN>toolEventInfo <SPAN class="operator token">&&</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>toolEventInfo<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">===</SPAN> <SPAN class="string token">"move-stop"</SPAN> <SPAN class="operator token">||</SPAN> event<SPAN class="punctuation token">.</SPAN>toolEventInfo<SPAN class="punctuation token">.</SPAN>type <SPAN class="operator token">===</SPAN> <SPAN class="string token">"reshape-stop"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">complete</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">else</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"cancel"</SPAN> <SPAN class="operator token">||</SPAN> event<SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"complete"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// graphic moving or reshaping has been completed or cancelled</SPAN> <SPAN class="comment token">// if the graphic is in an illegal spot, call sketchviewmodel's update method again</SPAN> <SPAN class="comment token">// giving user a chance to correct the location of the graphic</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">update</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> tool<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"reshape"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="comment token">// This function is called when a user clicks on the view.</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">setUpGraphicClickHandler</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">on</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="string token">"click"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="comment token">// check if the sketch's state active if it is then that means</SPAN> <SPAN class="comment token">// the graphic is already being updated, no action required.</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN>sketchViewModel<SPAN class="punctuation token">.</SPAN>state <SPAN class="operator token">===</SPAN> <SPAN class="string token">"active"</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> view<SPAN class="punctuation token">.</SPAN><SPAN class="token function">hitTest</SPAN><SPAN class="punctuation token">(</SPAN>event<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="token function">then</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>response<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">var</SPAN> results <SPAN class="operator token">=</SPAN> response<SPAN class="punctuation token">.</SPAN>results<SPAN class="punctuation token">;</SPAN> <SPAN class="comment token">// Check if the new development graphic was clicked and pass</SPAN> <SPAN class="comment token">// the graphic to sketchViewModel.update() with reshape tool.</SPAN> <SPAN class="comment token">//console.log(results);</SPAN> results<SPAN class="punctuation token">.</SPAN><SPAN class="token function">forEach</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="keyword token">function</SPAN> <SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> console<SPAN class="punctuation token">.</SPAN><SPAN class="token function">log</SPAN><SPAN class="punctuation token">(</SPAN>result<SPAN class="punctuation token">.</SPAN>mapPoint<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">if</SPAN> <SPAN class="punctuation token">(</SPAN> result<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>layer <SPAN class="operator token">===</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN>layer <SPAN class="operator token">&&</SPAN> result<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes <SPAN class="operator token">&&</SPAN> result<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">.</SPAN>attributes<SPAN class="punctuation token">.</SPAN>newDevelopment <SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> sketchViewModel<SPAN class="punctuation token">.</SPAN><SPAN class="token function">update</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN>result<SPAN class="punctuation token">.</SPAN>graphic<SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">{</SPAN> tool<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"reshape"</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">addGraphics</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">const</SPAN> vertices <SPAN class="operator token">=</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9258624</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.55590445</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9258630667</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.55587745</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9258671333</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.5557153</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.92626316670004</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.5557216</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.92625955</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.5558657</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9262584333</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.5559107333</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN><SPAN class="number token">175.9258624</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="operator token">-</SPAN><SPAN class="number token">37.55590445</SPAN><SPAN class="punctuation token">]</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="keyword token">const</SPAN> polygon <SPAN class="operator token">=</SPAN> <SPAN class="token function">createGeometry</SPAN><SPAN class="punctuation token">(</SPAN>vertices<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> validSymbol <SPAN class="operator token">=</SPAN> <SPAN class="token function">createSymbol</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="number token">0</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">170</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">0.8</SPAN><SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"solid"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">2</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="punctuation token">[</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="number token">255</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> newDevelopmentGraphic <SPAN class="operator token">=</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Graphic</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> geometry<SPAN class="punctuation token">:</SPAN> webMercatorUtils<SPAN class="punctuation token">.</SPAN><SPAN class="token function">geographicToWebMercator</SPAN><SPAN class="punctuation token">(</SPAN>polygon<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">,</SPAN> symbol<SPAN class="punctuation token">:</SPAN> validSymbol<SPAN class="punctuation token">,</SPAN> attributes<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> newDevelopment<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"new store"</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> graphicsLayer<SPAN class="punctuation token">.</SPAN><SPAN class="token function">add</SPAN><SPAN class="punctuation token">(</SPAN>newDevelopmentGraphic<SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">createGeometry</SPAN><SPAN class="punctuation token">(</SPAN>vertices<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> rings<SPAN class="punctuation token">:</SPAN> vertices<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> wkid<SPAN class="punctuation token">:</SPAN> <SPAN class="number token">4326</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="keyword token">function</SPAN> <SPAN class="token function">createSymbol</SPAN><SPAN class="punctuation token">(</SPAN>color<SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">,</SPAN> outlineColor<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="punctuation token">{</SPAN> type<SPAN class="punctuation token">:</SPAN> <SPAN class="string token">"simple-fill"</SPAN><SPAN class="punctuation token">,</SPAN> style<SPAN class="punctuation token">:</SPAN> style<SPAN class="punctuation token">,</SPAN> color<SPAN class="punctuation token">:</SPAN> color<SPAN class="punctuation token">,</SPAN> outline<SPAN class="punctuation token">:</SPAN> <SPAN class="punctuation token">{</SPAN> color<SPAN class="punctuation token">:</SPAN> outlineColor<SPAN class="punctuation token">,</SPAN> width<SPAN class="punctuation token">:</SPAN> width <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>script<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>head<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN>div id<SPAN class="operator token">=</SPAN><SPAN class="string token">"viewDiv"</SPAN><SPAN class="operator token">></SPAN><SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>div<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>body<SPAN class="operator token">></SPAN> <SPAN class="operator token"><</SPAN><SPAN class="operator token">/</SPAN>html<SPAN class="operator token">></SPAN><SPAN class="line-numbers-rows"><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN></SPAN>
ย ย The issue is that you are using Lat Long coordinates but when you specify the geometries spatialReference you use the view.spatialReference which is web mercator (line 4).
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createGeometry</SPAN><SPAN class="punctuation token">(</SPAN>vertices<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> rings<SPAN class="punctuation token">:</SPAN> vertices<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> view<SPAN class="punctuation token">.</SPAN>spatialReference <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="line-numbers-rows"><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN></SPAN>
You need to specify the spatialReference as {wkid:4326}
<SPAN class="keyword token">function</SPAN> <SPAN class="token function">createGeometry</SPAN><SPAN class="punctuation token">(</SPAN>vertices<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="keyword token">return</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">Polygon</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN> rings<SPAN class="punctuation token">:</SPAN> vertices<SPAN class="punctuation token">,</SPAN> spatialReference<SPAN class="punctuation token">:</SPAN> <SPAN class="keyword token">new</SPAN> <SPAN class="token class-name">SpatialReference</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">{</SPAN>wkid<SPAN class="punctuation token">:</SPAN><SPAN class="number token">4326</SPAN><SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">}</SPAN><SPAN class="punctuation token">)</SPAN><SPAN class="punctuation token">;</SPAN> <SPAN class="punctuation token">}</SPAN>โโโโโโ<SPAN class="line-numbers-rows"><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN></SPAN>
Hi Robert,
ย ย Thanks for the reply, finally i got a reply from this community, i have already tried it, but it didn't show my polygon on my coordinates, but if i comment this line, it show uneditable polygon
<SPAN class="">polygon coordinates in my websites db or any other place apart from that user can also draw polygon dynamically Ex:hazard zone near boundary , i have to save that also Could you pls guide me, if there is any other way that i could try. <STRONG>From the below code i am able to only display my property boundary from linz db.</STRONG> <STRONG>Now i have to make it editable and save it</STRONG>. </SPAN><SPAN class=""> </SPAN><CODE><STRONG>// spatialReference<SPAN class="">:</SPAN> <SPAN class="">new</SPAN> <SPAN class="">SpatialReference</SPAN><SPAN class="">(</SPAN><SPAN class="">{</SPAN>wkid<SPAN class="">:</SPAN><SPAN class="">4326</SPAN><SPAN class="">}</SPAN></STRONG><SPAN class=""><STRONG>)</STRONG> <STRONG>My task</STRONG> :I have to display property boundary with x,y coordinates, edit it and then save editedable </SPAN>
I tried to solve above code with updatesketchview model, but it do not help. Please help . Please help if am going in wrong direction to solve my problem
ย ย To be able to use a new class constructor (i.e. new SpatialReference) you will have to add the module to your require array.
<SPAN class="token function">require</SPAN><SPAN class="punctuation token">(</SPAN><SPAN class="punctuation token">[</SPAN><SPAN class="string token">"esri/views/MapView"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/WebMap"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/Graphic"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/layers/GraphicsLayer"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/widgets/Sketch"</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="string token">"esri/geometry/SpatialReference"</SPAN> <SPAN class="punctuation token">]</SPAN><SPAN class="punctuation token">,</SPAN> <SPAN class="keyword token">function</SPAN><SPAN class="punctuation token">(</SPAN>MapView<SPAN class="punctuation token">,</SPAN> WebMap<SPAN class="punctuation token">,</SPAN> Graphic<SPAN class="punctuation token">,</SPAN> GraphicsLayer<SPAN class="punctuation token">,</SPAN> Sketch<SPAN class="punctuation token">,</SPAN> SpatialReference<SPAN class="punctuation token">)</SPAN> <SPAN class="punctuation token">{</SPAN> <SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="punctuation token">.</SPAN><SPAN class="line-numbers-rows"><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN><SPAN>โ</SPAN></SPAN>
Ok Robert, i follow your steps, now my polygon is visible, but it is not editable, how canย i edit it ,ย if i click on it. Please find below updated code
Thanks Robert for being so patient and helpful to me, you are a life saver. As i was stuck in the task from the lastย 1 week, Besides this can you please tell me about any event or function like on mouse click up to get coordinates of polygonย ring vertices , when we edit it (to save it in my db), So that next time when i login to my app it gave me same editable polygon.
Any example will be helpful.
Thanks in advance.
ย ย Think carefully of you exact workflow (that would not interfere with standard editing of the polygon). I am not sure how a click event would work for what you want.
Robert , i just want updated vertices when the user reshape the polygon which i draw it for him through sketchviewmodel. is there any function to get updated vertices when polygon reshapes
One thing more robert i have get an error in console when i click on noneditable polygon
when using this code:
ย ย I am not sure what you are qualifying as editable and non editable but either way if the coordinates that you are trying to add a geographic then either way they must be converted to web mercator.
I am currently using the code above. I want to change the color of the polygon from light blue to red. How can I do that?
Kind Regards
Siyabonga Kubeka
you just have t chnage the rgb hereย
validSymbol <SPAN class="" style="color: #a67f59; background: rgba(255, 255, 255, 0.5); border: 0px; font-weight: inherit;">=</SPAN> <SPAN class="" style="color: #d74444; border: 0px; font-weight: inherit;">createSymbol</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">(</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">[</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">255</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">255</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">255</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">0.3</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">]</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #669900; border: 0px; font-weight: inherit;">"solid"</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">2</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN> <SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">[</SPAN> <SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">255</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">121</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">,</SPAN><SPAN class="" style="color: #990000; border: 0px; font-weight: inherit;">5</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">]</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">)</SPAN><SPAN class="" style="color: #999999; border: 0px; font-weight: inherit;">;</SPAN>
ใตใคใณใคใณใใใกใณใใผใฏๆ็จฟใๆดๆฐใฎใใฉใญใผใชใฉใใงใใพใใๅใใฆใงใใ๏ผ็กๆใขใซใฆใณใใ็ป้ฒใใฆใใ ใใใ
