Hey Ravi,
are there any news to the problems with the identify function for Image Server and Raster Catalog for version 10.4?
Thanks in advance!
Another issue with the Identify on a mosaic dataset is that it does not obey the transformations assigned to the mosaic. Visually the images are showing right, but when performing an identify they are off... i posted about this issue already here: http://forums.arcgis.com/threads/209...ransformations
1) Colormap doesn't support mapping a range of values. The workaround is to apply stretch function or arithmetic function (to stretch/squeeze to unsigned 8 bit) and then apply colormap function. This is what's applied to this temperature service:http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/World/Temperature/ImageServer2) "Time Value Format" is applied when you use a string/number to represent date. You don't need to specify "Time Value Format" when it's a date field.
At 10.0 Image Service supports Identify. Can this data be published as an image service?http://help.arcgis.com/en/arcgisserver/10.0/apis/rest/isidentify.html
