I am trying to list datasets within a directory. I have played with ListDatasets and ListFeatureClasses. These work successfully with geodatabase and CAD layers. How do I construct a Python script that lists shapefiles?
import arcpy # Set workspace environment to a folder arcpy.env.workspace = "c:/temp" # A list of shapefiles arcpy.ListFeatureClasses()
import os ws = "c:/temp" for file in os.listdir(ws): if file.endswith(".shp"): print file
Could this script be expanded to list multiple file types?.
import os ws = "c:/temp" for file in os.listdir(ws): if file.endswith(".shp") or file.endswith(".dxf") or file.startswith("str"): print file
import os, glob # Delete all files that contain the word 'points' for file in glob.glob("*points*"): os.remove(file)
ログインすると、投稿したり、更新をフォローしたりできます。初めてですか?無料アカウントを登録しましょう。
