You can't make the lepoard change its spots
I just define no parameters for the tool. Then if you add it to the menus using Customise.. you can add the tool as a button. Executing the button will not popup if there are no parameters.
Just FYI, I made 1 required parameter using a default text which basically just said "Click OK to run the program."
I was just curious if there is a way to get python scripts run out of Arctoolbox to skip the parameter input window for scripts which don't need input parameters.I have several scripts that run updates based on known layers, so they don't need any inputs or outputs. Any ideas? (besides going through VB/other programming language)
Couldn't you run them from PythonWin? Or even IDLE?
