you need do only widget: I have made a soe for this functionality.http://resources.arcgis.com/gallery/file/arcobjects-net-api/details?entryID=46F00F42-1422-2418-7F40-F039E02AA2F7
Did the code he recommended work? the link is broken so was wondering if I could get it from you?
Terry
This is new link: http://www.arcgis.com/home/item.html?id=e3bfa7c991e34aa8872c937ca9169507
If you need a complete solution you can see Roads and Highways of Esri Roads and Highways | ArcGIS Resource Center
When I browse to the soe to try and add the extension I click add but it does not add the extension. Is there a trick or am I missing something?
Would the problem be that I’m using 10.2.2?
What's the browser that you are using? If you use IE with ESC enabled you have this problem
I tried it on both IE and chrome and Firefox. I did receive the following error in Firefox. I tried to load the SOE from the 102/SOE/bin/release folder. The “Studioat.ArcGis.Soe.Rest.DSUtility.dll” file is in the same folder as the soe. Do I need to maybe open the project in Visual Studio and register that dll?
Terry,
Sorry I missed you inquiry. Another sorry, because I never did follow up with his link. Got busy with other stuff.
Michael
Domenico,
Is there a new SOE for 10.4.1?
https://github.com/nicogis/DS-Utility-SOE/releases
