map.zoomSliderVisible = false;
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="World Topographic Map"> <!-- ESRI dev. team sample - http://resources.arcgis.com/en/help/flex-api/samples/01nq/01nq00000044000000.htm --> <fx:Script> <![CDATA[ protected function onFullScreenButtonClick(event:MouseEvent):void { if (stage.displayState == StageDisplayState.NORMAL) { stage.displayState = StageDisplayState.FULL_SCREEN; } else { stage.displayState = StageDisplayState.NORMAL; } } ]]> </fx:Script> <s:layout> <s:VerticalLayout horizontalAlign="center" paddingTop="10" gap="10"/> </s:layout> <fx:Declarations> <esri:Extent id="initialExtent" xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000"> <esri:SpatialReference wkid="102100"/> </esri:Extent> </fx:Declarations> <s:Button id="btnFullScreen" icon="http://s.xanga.com/images/settings/icon_fullscreen.gif" label="Toggle fullscreen" click="onFullScreenButtonClick(event)"/> <esri:Map extent="{initialExtent}"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> </esri:Map> </s:Application>
As 1 of possible solution - U can play flash in full screen, but with some restrictions, such as no ability to use keyboard in full screen mode...
<?xml version="1.0" encoding="utf-8"?> <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009" xmlns:s="library://ns.adobe.com/flex/spark" xmlns:esri="http://www.esri.com/2008/ags" pageTitle="World Topographic Map" creationComplete="init()"> <!-- ESRI dev. team sample - http://resources.arcgis.com/en/help/flex-api/samples/01nq/01nq00000044000000.htm --> <fx:Script> <=!=[=C=D=A=T=A=[ import com.esri.ags.geometry.MapPoint; import mx.controls.Alert; import mx.core.FlexGlobals; import mx.events.CloseEvent; import mx.utils.URLUtil; private var extCenter:MapPoint; protected function onFullScreenButtonClick(event:MouseEvent):void { if(flashVersion.major == 11 && flashVersion.minor >= 3){ var bUrl:String; if(FlexGlobals.topLevelApplication.url.indexOf("file")>-1){ bUrl = "local"; }else{ bUrl = URLUtil.getServerName(FlexGlobals.topLevelApplication.url); } Alert.show("You are about to switch to full screen mode. You must click allow " + "when you see an overlay that says '" + bUrl + "' is now full screen. Press esc to exit. " + "You must click allow to enable keyboard interaction. " + "Do you want to switch full screen mode?", "Warning", Alert.YES|Alert.NO, null, alertClickHandler, null, Alert.YES); }else{ /* If not in full screen mode, ask if they want to switch to full screen mode. */ Alert.show("You are about to switch to full screen mode, that limits your interaction " + "with the map in a couple of ways. You can not enter text into widgets like " + "the parcel search widget or other widgets when you are in full screen mode. " + "Certain keyboard shortcuts will not work in full screen mode also. " + "Do you want to switch full screen mode?", "Warning", Alert.YES|Alert.NO, null, alertClickHandler, null, Alert.YES); } } private var flashVersion:Object = new Object();// Object to hold the Flash version details protected function getPlayerVersion():void { var versionNumber:String = Capabilities.version;// Get the whole version string var versionArray:Array = versionNumber.split(",");// Split it up var length:Number = versionArray.length; var osPlusVersion:Array = versionArray[0].split(" ");// The main version contains the OS (e.g. WIN), so we split that off as well. // Populate the version object (the OS is a string, others are numbers): flashVersion["os"] = osPlusVersion[0]; flashVersion["major"] = parseInt(osPlusVersion[1]); flashVersion["minor"] = parseInt(versionArray[1]); flashVersion["build"] = parseInt(versionArray[2]); } protected function alertClickHandler(event:CloseEvent):void { if (event.detail==Alert.YES){ extCenter = map.extent.center; if(flashVersion.major == 11 && flashVersion.minor >= 3){ systemManager.stage.displayState = StageDisplayState.FULL_SCREEN_INTERACTIVE }else{ systemManager.stage.displayState = StageDisplayState.FULL_SCREEN; } var timer:Timer = new Timer(500, 1); timer.addEventListener(TimerEvent.TIMER_COMPLETE, timerComplete); timer.start(); function timerComplete(evt:TimerEvent):void{ map.centerAt(extCenter); } } } protected function exitFullScreen(evt:FullScreenEvent):void { if(!evt.fullScreen){ var timer:Timer = new Timer(500, 1); timer.addEventListener(TimerEvent.TIMER_COMPLETE, timerComplete); timer.start(); function timerComplete(evt:TimerEvent):void{ map.centerAt(extCenter); } } } protected function init():void { systemManager.stage.addEventListener(FullScreenEvent.FULL_SCREEN, exitFullScreen); getPlayerVersion(); } ]=]=> </fx:Script> <s:layout> <s:VerticalLayout horizontalAlign="center" paddingTop="10" gap="10"/> </s:layout> <fx:Declarations> <esri:Extent id="initialExtent" xmin="-13635000" ymin="4541000" xmax="-13625000" ymax="4547000"> <esri:SpatialReference wkid="102100"/> </esri:Extent> </fx:Declarations> <s:Button id="btnFullScreen" icon="http://s.xanga.com/images/settings/icon_fullscreen.gif" label="Toggle fullscreen" click="onFullScreenButtonClick(event)"/> <esri:Map extent="{initialExtent}" id="map"> <esri:ArcGISTiledMapServiceLayer url="http://server.arcgisonline.com/ArcGIS/rest/services/World_Topo_Map/MapServer"/> </esri:Map> </s:Application>
//Add params.allowFullScreenInteractive = "true"; //Add <param name="allowScriptAccess" value="sameDomain" />
