<layer> <token /> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <enableprintgrid>true</enableprintgrid> <name>Unique Join Test</name> <url>http://gislap183:6080/arcgis/rest/services/ParcelTest/MapServer/1</url> <expressions> <expression alias="PPIN" textsearchlabel="Search by PPIN"> <values> <value prompt="Example: 1998" uniquevalsfromfield="Parcels3.PPIN" isvaluerequired="true" autosubmit="false">Parcels3.PPIN = '[value]'</value> </values> </expression> </expressions> <graphicalsearchlabel>Use one of the graphical search tools to select a Parcel</graphicalsearchlabel> <spatialsearchlayer>true</spatialsearchlayer> <titlefield>Parcels3.NAME</titlefield> <fields all="false"> <field name="Parcels3.PPIN" gridfield="true" /> <field name="Parcels3.PARCEL_NUMBER" gridfield="true" /> <field name="Parcels3.ADDRESS_1" gridfield="true" /> <field name="Parcels3.TAX_DISTRICT" gridfield="true" /> </fields> <links/> <zoomscale usegeometry="true" zoompercent="1.6" /> <autoopendatagrid>true</autoopendatagrid> <queryattachments>false</queryattachments> </layer>
<expression alias="Location" textsearchlabel="Search by Location"> <values> <value prompt="Choose from dropdown list:" uniquevalsfromfield="FACLIB.FAC$OWN.structure_existing_area.Location" isvaluerequired="false">FACLIB.FAC$OWN.structure_existing_area.Location = '[value]'</value> </values> </expression>
<layer> <token></token> <definitionexpression></definitionexpression> <enableexport>true</enableexport> <enableprintgrid title="Buildings">false</enableprintgrid> <name>Building</name> <url>https://widmamaps.us/dma/rest/services/WIARNG_Facilities/Fac_RPI_WMAS_Cached_WithRPIJoins/MapServer/0</url> <expressions> <expression alias="Location" textsearchlabel="Search by Location"> <values> <value prompt="Choose from dropdown list:" uniquevalsfromfield="FACLIB.FAC$OWN.structure_existing_area.Location" isvaluerequired="false" >upper(FACLIB.FAC$OWN.structure_existing_area.Location) LIKE upper('%[value]%')</value> </values> </expression> </expressions> <graphicalsearchlabel>Use a shape to select buildings</graphicalsearchlabel> <spatialsearchlayer>false</spatialsearchlayer> <titlefield>Location</titlefield> <fields all="true" > <field name="FACLIB.FAC$OWN.structure_existing_area.Location" alias="Location" gridfield="true" /> <field name="FACLIB.FAC$OWN.structure_existing_area.instln_id" alias="Site Number" gridfield="true" /> <field name="FACLIB.FAC$OWN.structure_existing_area.facil_id" alias="Facility ID" gridfield="true" /> <field name="FACLIB.FAC$OWN.structure_existing_area.structname" alias="GIS Name" gridfield="true" /> <field name="FACLIB.FAC$OWN.PRIDE_RPI.PRIDEName" alias="PRIDE Name" gridfield="true" /> <field name="FACLIB.FAC$OWN.PRIDE_RPI.TotalQty" alias="Building Total SF" numberformat="0|," gridfield="true"/> <field name="FACLIB.FAC$OWN.PRIDE_RPI.PlacedInServiceDate" alias="Acquisition Date" gridfield="true" /> <field name="FACLIB.FAC$OWN.PRIDE_RPI.OrigCostToGov" alias="Acquisition Cost" currencyformat="$|0|," gridfield="true" /> <field name="FACLIB.FAC$OWN.PRIDE_RPI.OperationalStatus" alias="Operational Status" gridfield="true" /> <field name="FACLIB.FAC$OWN.PRIDE_RPI.DoDInterestType" alias="Interest Type" gridfield="true" /> </fields> <links> <!--<link alias="View Traffic Photo" disablelinksifnull="true"> <![CDATA[{URL}]]> <icon><![CDATA[assets/images/i_camera.png]]></icon> </link>--> </links> <zoomscale usegeometry="true" zoompercent="2"></zoomscale> <autoopendatagrid>false</autoopendatagrid> <queryattachments>false</queryattachments> <relates> <!--Area Records--> <relate id="0" label="Building Area Data" enableexport="true" icon="assets/images/WILOGO_small.png"> <fields all="false" > <field name="AreaID" /> <field name="Name" /> <field name="AreaCatcode" /> <field name="AreaQuantity" numberformat="0|,"/> <field name="AgreementSupptCode" /> <field name="UsingOrg" /> <field name="SustOrg" /> <field name="SustFund" /> </fields> <zoomscale usegeometry="false" zoompercent="1.6" /> </relate> </relates> <symbology> <picturemarkersymbol url="assets/images/reddot.png" height="30" width="30" xoffset="0" yoffset="0" /> </symbology> </layer>
Hello,
I'm having this same issue with the dropdown list for the eSearch widget failing to populate, and I'm curious how the issue was resolved.
I'm using eSearch 2.6.1. The layer that the search is based on is hosted on ArcGIS for Server. This layer has around 3,500 features. I've configured the update search layer properties as follows:
And my expression selects Unique municipality names:
As you can see, the tool appears to be working, meaning that it is processing the unique municipality name values. However, the list never populates and it never appears to read any values since it remains at '0 of 3568.'
One thing that is worth mentioning is that I originally hosted this layer on ArcGIS Online rather than Arc Server. When it was on AGOL, I was able to get the list to populate, which causes me some concern that the issue is how the Search URL to Arc Server is being interpreted. Could this be the issue?
Paul,
You have posted this in the Old Flex Viewer space but you screen shots are from WAB eSearch. You should start a question in the https://community.esri.com/groups/web-app-builder-custom-widgets?sr=search&searchId=8c700fb1-f4d8-4a72-8568-9e92735b1bd2&searchIndex=0 group.
