Hello, i have a problem with using GTFS tools in Pro :
I work on Pro 2.3.2 version.
My GTFS Data come from severals sites :
- https://dataratp2.opendatasoft.com/explore/dataset/offre-transport-de-la-ratp-format-gtfs/information/
- https://www.data.gouv.fr/fr/datasets/transport-donnees-gtfs/#_
-https://www.data.gouv.fr/fr/datasets/gtfs-du-reseau-de-transport-tbm-offre-de-service-bus-et-tram/#_
I face the same issue from thoses Data...
i run the tool, i get no error message, but no feature class is created on my GDB..
I closed, reopened the project...NO DATA is stored in my GDB
Thanks for help
Hi Asma NKHILI,
Until a few minutes ago I did not have any experience with this GTFS specification (General Transit Feed Specification). But now I have a Feature Class with all the stops in Metz (see screendump below):
(Running ArcGIS Pro 2.3.2 like you)
So, I don't know what is going wrong on your side...
Egge-Jan
It's working fine for me also. (I am the developer of those tools.) Do other geoprocessing tools successfully produce output? I suggest you check if you have the same problem with other tools. Regardless, you might need to call Esri Support in your country. It sounds like a problem with your particular installation or something.
