Why in ArcGis Online the decimal separator in the number format to Mexico is a (comma) ',' and not the '.' (dot)?
Mexico use the dot to separate decimal numbers ('999,999.99' ) and the date format is 'dd/mm/yy' .
Please modify this item.
Thanks
I have the same problem. I need to import a table with numbers "." followed by decimals, but ArcGis online thinks they are fields with strings ...
