Getting error in IE11. No error in other browsers.
For example, using a basic Esri sample below errors in IE.
Same issue in 4.12
Version 3.9 works in IE
Move your script tag to the header:
Example:
JS Bin - Collaborative JavaScript Debugging
Thanks, but I am using wordpress and need esri to load as defered and in footer, otherwise it gets multipleDefined errors from jQuery. Chrome\Firefox\Opera\Edge all work as is.
I found the issue.
I am using pdf.js to generated PDF files in another part of my website, and unrelated to Esri. The map works when I remove the reference to pdf.js.
