Field Maps 26.2.2 Build 2812 - iOS
We have had field teams reporting that the new photo attachment question is causing the form submission to fail, and then the photos will sometimes disappear. I was able to replicate this in office, believe it is related to signal issues, though it seemed to occur even on 5G. The issue is not necessarily that the photos are failing to submit, it is that they disappear from the form after failure.
Workflow that the field team is experiencing -
1. Try to submit a form that has a photo attached to the new "General" question
2. It spins, connection is interrupted, etc. and they get the following error:
"Unable to Submit. 1 attachment failed to upload"
Looking at the troubleshooting logs it says "The network connection was lost."
3. They can choose to either cancel or view the error, which one is chosen does not seem to impact anything.
4. Can try again, but then gets the error:
"Unable to Submit. The operation couldn't be completed. (ArcGIS.ArcGISError error 1.)"
Again the troubleshooting says "The network connection was lost."
4. They try to submit again, it fails again, and then photo attachments disappear from the form.
I don't think that the submission failing is necessarily a problem, working online is subject to occasional network connection issues, but the photos disappearing is causing real headaches for field personnel.
See the attached videos for the two errors, and how the photos are no longer in the form.
