Within the Manager App, where do you configure the visibility and order of fields showing in the table view?
Hi @ACrateau
You can adjust the fields order/visibility in the web map using Map Viewer or you can use the layer options in the Manager configuration. If you go to the Interactivity section > Layer options > You can select the layer you want to adjust the fields for.
Thanks!Sarah
Thank you, Sarah! The Layer Options in the app worked perfectly.
One other question for you: it looks like this app does not support URL parameters for opening the app with a record selected. Is there any plans for this in the future? -- We are using a webhook (Power Automate) to email staff when a new request is submitted in the Citizen Reporter, and it would be powerful to include a URL for opening the app to the specific request.
Sarah,
It appears that the latest version of the Public Notification Instant App template has removed the ability to reorder fields in the Manager configuration. Or is this only available for hosted feature layers?
I have a feature service in which the layers have their fields in a specific (expected) order. In Map Viewer, I have configured the pop-up to display information in the same order as the layer schema. The fields list, however, just displays the fields in alphabetical order with no option to order them based on the underlying schema. This is an overall frustration Enterprise-wide but not your issue to solve (but please advocate for that option!).
When I export to pdf in the Notification Instant App, the output simply lists my fields in alphabetical order. Again, the pop-up is in correct order, and there is no way to change the field order within the Manager configuration. What is governing the order of the listed fields? And how do I change them if it is simply pulling them from the fields list?
I beat on this issue a bit more. For the benefit of anyone else experiencing this same issue, I finally deleted the fields list in my pop-up and created the same list using a Text content item. I'm unsure why the fields list order in the pop-up isn't being honored.
