I have a publicly available dashboard. One of the list features is populated via a survey123 form that I set up in Survey123 connect. Its a simple list, connected to points on a map. the list shows the events chronologically. On the backend I can see the populated list (screenshot) but in the public facing dashboard it says no data (screenshot). I have checked all the permissions multiple times to ensure that the layer and form are shared with "everyone", I created a view layer and shared that with "everyone" to see if that would work. I am not sure why it is not working unless if its a problem that the survey was set up in S123 connect. Are there any issues that others can think of that would make this happen?
Is query enabled on the layer? Does it make a difference having it on/off? Did your view work? In settings also look to see if editors can only see their own features is selected.
