When I create a new GUID field in AGOL > Contents > Fields, the Add Field dialog says "Store a 36 character string...".
But when I look at the resulting field, its length is 38.
Why does it say 36 when the result is 38?
Esri Case #04168794 - ArcGIS Online - Add Field dialog says GUID field length will be 36, but resulting field length is 38
This is expected because 38 includes dashes and brackets. For reference, I've included an example below. (More information regarding this can be found here.) Example: {7ec3018d-4a49-4a13-8e15-005846b25848}
Calculate Unique Identifier Values Similar to Global IDs perhaps this
Any reason for not creating relationship classes and tables in Arc Pro? @Bud
Good point. I have to admit, I haven't used relationship classes much. I'll try them out. Do they automatically populate GUID fields?
