The filter works as expected until I click apply, then the spatial disappears from the map. The attribute table correctly reflects the filter. Possibly only date filters.
This went out last night and the issue should be resolved now. Let me know if you see an issue. thanks!
Maybe related to this bug? See this post:
https://community.esri.com/t5/arcgis-online-questions/filter-using-quot-in-the-last-quot-date-no-longer/m-p/1687013#M67970
Hi @TL2,This is likely the same issue that is reported here: Re: Filter using "in the last" date no longer work... - Esri Community.
Please let us know if the behavior you are seeing is different.Thank you!
Katie
If you can share the map/layer I can take a look.
I am having this problem currently but am not filtering dates. I am filtering a string of numbers (UserID) and it has disappeared and does not come back up. Unable to filter anything on my layer, even hosted layers that I previously filtered are no longer there. It is just blank
We are hoping have this issue patched tonight.
