Hi All,
Is it possible to remove just 0 labels from my line chart that is based on time/date. I want to total count label to be visible but remove 0's from the chart as well as the same between the different peaks.
What happens if you do a filter for those values (where the value does not equal 0)? Does it truncate your chart in a way that does not look good?
Thanks @AdrianWelsh No change unfortunately, is it because it's a date field?
Possibly so. Can you change the value of the 0 to a null value, therefore nothing should show up?
Did that nothing changed. To explain further the 0 values don't exist within the data, that's where I am having trouble filtering it out.
Hmm, maybe I am not understanding the data very well. I notice that if I try this with some data that I have, it shows me a 'count' of all points that occurred on those dates. This is how it looks natively (similar to yours, except it shows a '1' instead of a 0).
But if I choose Parse Dates, it looks a little more spread out
Maybe that could work in yours?
I am using hour instead of day. And my data is aggregated using data expression. Instead of the manually populated date/time field (there was a date formatting issue). I am using the creation date field.
@AdrianWelsh Thank you for troubleshooting with me. My end users didn't complain but I would love to see it cleaned up.
