Regarding editing break values for quantity-driven symbols such as graduated colors or graduated circles.
Has this ever happened to you?
1. The upper bounds were automatically set to "<=2.2,<=12.8,<=17.9,<=25.3,<=39," but I want to set them to "<=10,<=20,<=30,<=40,<=50," so I manually change them from top to bottom.
2. As soon as I change "2.2" to "10" and "12.8" to "20," the symbol is automatically loaded and the order changes to "<=10,<=17.9,<=20..."
3. If I then accidentally change the second-placed "17.9" to "20," one class will be lost. I'll have to change the spacing back to "Manual" and start over.
4. I need to make sure I don't accidentally overwrite "20," but since the color order has also changed, it's hard to intuitively know which upper limit to rewrite.
I need to change the upper limit value many times, and every time I do, I'm plagued by this "automatic order change function."
I've been putting up with this hassle for years, what do you all do?
Is there an easier way? I'd appreciate it if I've overlooked something.
I wish it were like ArcMap, where you click "Apply" after setting everything up and the symbols are updated.
