Hello,how get the value of joined attributtes like string valueCode = m_currentFeature.get_Value(indexField).ToString();the index of specific joined field in FeatureClass i get with public static int FindAttributeIndexWithJoinedFields(frmKarte form, string layerName, string attributName) { IFeatureLayer actFeatLyr = (IFeatureLayer)form.axMapControl1.Map.GetLayerByName(layerName); ILayerFields fields = (ILayerFields)actFeatLyr; return fields.FindField(attributName); }Can you help me, please?Thank you!
Hi jamesfreddyc IDisplayTable dispTable = (IDisplayTable)actFeatLyr; ITable table = dispTable.DisplayTable; IRow row = table.GetRow(feature.OID); Debug.Print(row.get_Value(index).ToString());Thanks you!Perfect!
