Have installed ArcGIS Monintor 2025.0 on couple of machines. Post installtion the ArcGIS MOnitor home page doesn't load up.
Has anyone faced similar issue?
In one of the box I have insatlled POSTGRES 15.13 and on another 16.9.
Hi @SatishNaik1
Sorry to hear you are having this issue.
Can you check permissions for the monitor service account in the key directories:
C:\Program Files\ArcGIS\MonitorC:\Users\<MonitorAccount>\AppData\Local\ESRI\ArcGISMonitor
Are ports 30443 for HTTPS or 30080 for HTTP closed?
Another few things to run through and check:
1. Check if the Monitor Server service is running via Windows Services.2. Run Monitor Server in debug mode to identify startup errors:
Powershell$env:LOG_LEVEL='debug'.\arcgis-monitor-server.exe --serve
3. Verify DNS resolution:• Run nslookup <server IP> and ensure it returns a valid domain name.• If it fails, configure reverse DNS or update your local DNS settings.4. Ensure required ports are open (30443 or 30080).5. Check PostgreSQL logs for connection or schema errors.6. Reinstall or reconfigure Monitor if .env or config-store folders are corrupted.
Here is documentation and a previous ArcGIS Monitor posts
Problem: Unable to Access the ArcGIS Monitor Site
Solved: Monitor 2025 Agent service not starting on server - Esri Community
Failed to upgrade ArcGIS Monitor from 2024.1 to 20... - Page 2 - Esri Community
Common problems and solutions—ArcGIS Monitor | Documentation
I hope some of this can point you in the right direction to get this up and running
Thanks Daniel for the input! Shall try out some of the suggesions you have provided and update you.
Ports , accounts are all fine. Tried few other workarounds still not able to resolve the issue.
Hi @SatishNaik1,Please contact Esri Tech Support so they can help investigate the issue in more detail.
