The Philippine Statistics Authority (PSA) published the Philippine Standard Geographic Code (PSGC) (Philippine Standard Geographic Code | Philippine Statistics Authority | Republic of the Philippines), and I found it on GitHub (GitHub - altcoder/philippines-psgc-shapefiles: High resolution Philippine PSGC administrative boundaries). Can the ESRI team update this based on the latest administrative boundary? One example is attached, showing that the administrative boundary is different from the actual one published by PSA in their PSGC.
It's probably better to submit your feedback through the Basemap feedback map.
If you have feedback, you can enter it here: https://www.arcgis.com/home/item.html?id=ebdfa4146680410bb952c7d532ea5407
